Yes. Those are the rules.
Please see attached image.
The third picture shows a common mistake. You draw a line between the two perpendicular walls of a room in an interior elevation, thinking that it should split the face but it does not split. The reason is that the wall you are trying to split does not end at the intersection of those perpendicular walls, but extends some feet away to the right or the left, but you can't see that in an interior elevation.
Alfredo Medina
info@planta1.com
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
