Revit Architecture
Revit Architecture
Valued Contributor
jraesly
Message 1 of 5 (266 Views)
Some entities not plotting
266 Views, 4 Replies
12-12-2012 08:04 AM
Our 50% plots don't print some entities.  They plot fine at 100%.  This occurs across multiple workstations.  I first made sure that all the systems were updated with the latest updates and that the plotter driver was updated to see if that would fix it.  No change.  All workstations have Revit 2012 with update #2.  Printing to and OCE TDS600 with the newest driver.
Have you tried changeing from Vector to Raster, or vice versa?
This sometimes corrects the problem.
You might also try printing to PDF with a PDF print driver, then print hard copies from the PDFs.
ccollins
Message 2 of 5 (264 Views)
Re: Some entities not plotting
12-12-2012 08:07 AM in reply to: jraesly
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Valued Contributor
jraesly
Message 3 of 5 (254 Views)
12-12-2012 08:50 AM in reply to: ccollins
We have tried PDF too.  They seem to work ok. Unfortunatly I can't say if we created the PDF at 100% then printed the PDF as a 50% plot.    How do you suggest changing from vector to raster?  Where do I change that?
ccollins
Message 4 of 5 (245 Views)
12-12-2012 12:16 PM in reply to: jraesly
Change Raster>Vector settings in Revit's print settings.
see attached.
Cliff B. Collins
St. Louis, MO
Valued Contributor
jraesly
Message 5 of 5 (219 Views)
12-14-2012 09:02 AM in reply to: ccollins
We did make that change and it did work.  Thanks so much for the information.  I would like to know why vector is not printing correctly.  A bug maybe?
