Revit Architecture
aalonsojaver
Message 1 of 4 (246 Views)
SOLID MASS, SOLID ELEMENT WITH MATERIAL
246 Views, 3 Replies
08-31-2012 02:41 PM
I need to add a kind of layer to my  roof to represent an "empastado", and element that we add to the constructions in México, the way I created this element is using  a Mass.
I want to make the mass solid to add it a material, but i cant, because the mass is divide it in faces, exists something in revit thats create like a solid element with the form that i want?
Product Support
alan.quinn
Message 2 of 4 (217 Views)
Re: SOLID MASS, SOLID ELEMENT WITH MATERIAL
09-04-2012 09:22 AM in reply to: aalonsojaver
I'm not sure on the material you want to add but in any event all you can really do is add the layer to the roof family, or create a roof type that only contains the layer and create that on top of another roof. Go here for information on Roof Properties: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0...
Thanks for posting and I hope this helps.
Alan Quinn
Support Specialist
Product Support
aalonsojaver
Message 3 of 4 (195 Views)
09-05-2012 01:19 PM in reply to: aalonsojaver
Thank you for your answer
I dont know if that going to result with a Roof, beacuse I need to unit de point 1 with the point 2 (image), when I modify the subelements of the roof or floor, the thickness dont change, only the slope.
Product Support
alan.quinn
Message 4 of 4 (176 Views)
09-06-2012 02:53 PM in reply to: aalonsojaver
I'm still not clear on your questing and your last image is not helpful. If you create a floor or roof by MASS you should be able to set up the thickness first, then apply it. Updating after by changing the properties will allow you to change the thickness.
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
