Snapping to the viewer when using the measure tool,
5 REPLIES 5
JamaL9722060
877 Views, 5 Replies
I wanted to measure the default distance between the viewers (attached) but sounds that the snaps are not working.
How can the snaps be activated so that I can measure the distance between the viewers with snaps?
The measure tool is used to snap fine in Revit 2012
Thank you
Best
Jamal
Jamal Numan
5 REPLIES 5
BalajiHTI
in reply to: JamaL9722060
Hello Jamal,
The measure tool can only measure the distances between model or drafting elements like lines, etc. It can not snap into view references like Elevations, Sections, Callout.
Thanks!
JamaL9722060
in reply to: BalajiHTI
Many thanks bala8vijay for the input.
I think it was possible to do this in 2012. Please, have a look on the attached screenshot.
Best
Jamal
Jamal Numan
BalajiHTI
Oh.. Thats new to me. May be they removed for later versions?
David_W_Koch
Are you certain that there is no other geometry in the area?  I tried this in Revit Architecture 2012, and while I can eyeball the measurement, I was not able to snap to any geometry of the elevation markers.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
JamaL9722060
in reply to: David_W_Koch
Hi David,
That could be possible. I did it at the very beginning use of the Revit and took a screenshot. At that time, I wanted to check the default distance between the elevation markers.
Recently, I wanted to show this (the default distance between the elevation markers) to a colleague but I failed to snap.
Best
Jamal
Jamal Numan
