Snapping to the viewer when using the measure tool,
I wanted to measure the default distance between the viewers (attached) but sounds that the snaps are not working.
How can the snaps be activated so that I can measure the distance between the viewers with snaps?
The measure tool is used to snap fine in Revit 2012
Thank you
Best
Jamal
Many thanks bala8vijay for the input.
I think it was possible to do this in 2012. Please, have a look on the attached screenshot.
Best
Jamal
Hi David,
That could be possible. I did it at the very beginning use of the Revit and took a screenshot. At that time, I wanted to check the default distance between the elevation markers.
Recently, I wanted to show this (the default distance between the elevation markers) to a colleague but I failed to snap.
Best
Jamal
