Small Dimension with leader placement
3 REPLIES 3
Jleibold
612 Views, 3 Replies
Hello All;
Is there a setting or setup parameter for dimension leaders for small dimensions?  What I am looking for is when you dimension a string of walls, the wall thickness, say 3 1/2", is in line similar to the larger dimensions, but I have to drag each smaller dim. (3 1/2") to a clear area.  SO can you set that dim. style or system parameter for dim. that don't fit between the leader lines above or to the right side or below dim. line?  Or are you stuck with moving every one with the grip?
Thanks in advance....
Jleibold
3 REPLIES 3
LisaDrago
in reply to: Jleibold
Your are stuck moving them indivudally. You can control the offset from the dimension line but it will not move it to the left or right.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Jleibold
in reply to: LisaDrago
LisaDrago,
Thanks for the reply....I figured that, but since I'm a novice & learning, I thought I'd ask....
Jleibold
LisaDrago
That is why we are here!
If you cannot find an answer from a previous post, go ahead and post the question.
We are here to help!
LD
