I am workgin on the project with sloping roof. I have drawn beams with slope. however when I am drawing slab with slopes I am not geeting this slopes. There is gap between the beams and slab. I have attached screen shot for more information. Also I need to aplly load sfor this sloped roof. so can you please help me out in this issue.
Sampath
Your Name
Thank you for the reply.
I tried making slope in revit using edit mode and giving different elevation for different points to match the slope required. Hoowever Analytical model doesnt show same slope. I have attttached pictures of same model in 3-D model and analytical model.
The analytical model of a floor/slab will not slope if you use the slab shape edit tools.
The only way to slope a slab analytical model is to use a slope arrow to slope the floor.
Your other option is to leave the floor Analytical Model flat and to project the beam Analytical models to the floor or the level (using auto-detect, or a manual vertical projection via the property palette)
If you are not running a Structural Analysis, you should feel free to disable, ignore, or hide the analytical model.
If you have more questions about Analytical Model, you will have more luck getting answers posting in the Revit Structure discussion group:
http://forums.autodesk.com/t5/Autodesk-Revit-Structure/bd-p/153
Joe
