Hi.
Is it possible to make windows to fit the corner in this sloped glazing.?
Solved by constantin.stroescu. Go to Solution.
Do you know if there is any good tutorial that shows how to set it up in the family?
If this can not be done by Edit Type settings , you cand do it manualy:
Your Name
The grid is in the desired position, I just need the windows to fit this pattern 🙂
Then Indead Adaptative points is suited:
Your Name
Autodesk University:
AB2463-L | An Introduction to Autodesk® Revit® Massing, Surface Divisions, and Adaptive Components |
Your Name
When I try to make the family, I don't get the option to make a sweep or extrusion?
Indeed yo haven't ...Revit "knows well what to do"
Your Name
Thanks alot, but it comes out whit an odd shape when I try to place the points in the project. Its like the frame is inside out and I kan only choose 4 points, there is 5 in most of the windows.
As you can see the shape is flipped from what I have drawed.
The above is an image of the original window family - not the adoptive one 🙂
Adaptative points can be made not only wit 4 points...but you have to make it in slightly diferent manner (now you don;t use prefabricated style)
Your Name
keep the order when inserting in project!
Your Name
I made 5 points and loaded the family into the project, when I mark the 5 corners I get this shape.
What is it that im doing wrong?
Have you tried creating a Mass and then applying a Curtain System by Face?
did you use 3d snap when you made the family...and Place on Face when inserted in project?
Your Name
