Has anyone dealth with sloped buildings in any version of Revit. We are dealing with agricultural buildings which in some cases require the entire building to be sloped from footings to walls, roofs and structure. BTW, footings do not react well to sloped walls. I am trying to avoid adaptive modelling but I am wondering if it it the only way that this can be done.
Any help is greatly appreicated.
In such type of situation I use:
Constantin Stroescu
I think I should've been more specific. I have attached a picture of what I'm taking about when I say sloped buildings. It is obviously exaggerated, but we get buildings that slope upwards of 40" over a 200' length.
I did this using edit profile, but this is very time consuming and footings will not follow the wall. I could recreate them as beams, but this is an extra step I do not want to take.
I think that Edit Profile function (as you suggest ) using Reference Planes as guide for slope angle and geometric construction is the right solution.
As about foundation, although I am an architect not an engineer , I believe that this must be realized in steps so to have only vertical load on soil and no horizontal component (as in case of non zero angle foundation ) that can facilitate a slide movement of the building...
Constantin Stroescu
