Hi guys
I want to place a Skylight on a Slope Roof that will be channel vertically thru the Raked Ceiling System. I need to show this skylight on Roof and Ceiling plans.
How do you guys do it? without tracing lines or using Vertical command
Solved by constantin.stroescu. Go to Solution.
Use a Generic Model Roof Base Family with an incorporated Void....Loaded into the project it will place on the roof surface and it will cut it.
Constantin Stroescu
Thanks Constantin for your response.
I must be doing something wrong. I create the void does cut the roof but It doesn't cut the ceiling. Can you please have a look at the file I attached to see if I did something wrong.
Constantin Stroescu
