Sketch Up to Revit
3 REPLIES 3
AlmightySR
400 Views, 3 Replies
Sketch Up to Revit
Anyone know how to get a Sketchup model into Revit as a wall?
I was thinking the create under model pull down and wall then insert the
exported sketchup file as a mass. but cant get it to work.
Please help with ideas.
3 REPLIES 3
penningtoncd
in reply to: AlmightySR
What kind of wall model are you trying to create? Are you trying to import a Sketchup model as a wall type? I don't think that will work. Message was edited by: axlerodhomeboy
AlmightySR
Yes I am trying to pull the sketchup model in as a wall type. I tried DXF
and DWG formats. I think the key is importing at the stage that you are
making a "Solid Form".
wrote in message news:5071104@discussion.autodesk.com...
The only way to get Sketchup to Revit is through mass modeling. Export the
3D Sketchup model as dwg and then import into Revit 3D view and use mass
modeling (wall, floor, roof by face).
David Haynes, AIA
Ideate, Inc.
www.ideateinc.com
wrote in message news:5070847@discussion.autodesk.com...
