Make sure to create a duplicate view of the site plan and set its phasing to Existing, then select the site toposurface and change its phasing to be existing. Now open a New Construction phase site floor plan view and select the site toposurface and on the Site tab (2009) under the Design Bar or Massing & Site Ribbon (2010) select Graded Region.
In 2009 you will receive a Graded Region dialog window with a message to make sure your toposurface is phased to a prior phase and that you should be in a view of a future phase to be able to grade the region. In 2010 you will receive no message if everything is setup properly.
In 2009 check the box to copy the internal points and then pick select and edit button to select the toposurface you want to regrade. In 2010 select from the Edit Graded Region dialog window Create a new toposurface exactly like the existing one - both internal and perimeter points are copied. Acopy of the original (Existing Phase) toposurface has been created on top of the existing toposurface. To verify you have both toposurfaces place a apparent crossing or window selection box around the toposurface and you will see in the lower right-hand corner of the Status Bar were the select filter icon is located that 2 have been selected.
Now turn off the existing toposurface in the New Site plan view (Hide in View) and edit the new phase toposurface to regrade it for your drainage and landscape.
Mel Persin, aia
Mel Persin, aia
