Our model uses several material types for insulation, mostly rigid variations at this point. The various materials are used in floor, wall and roof systems. Is there a way to create a single schedule that would list insulation quantities across all three system types?
Solved by ccollins. Go to Solution.
You could consider using Parts, to "break" the Floors, Roofs and Walls into their subcomponents.
Then create a new Schedule of Parts, and Materials.
This could provide a possible solution for what you are trying to do.
Another possibility is a simple Material Takeoff Schedule, and use a Filter in the schedule to show only the Insulation Material names.
cheers
I think you're right. I'm new to this and thought you had to pick a single system to create the schedule. Picking multi-category and filtering on various material parameters looks like it will work. Thanks.
