I am a student new to HVAC in Revit. I am having trouble making connections with a VRF duct system to supply diffusers. Everything seems to fail. I have set the supply diffusers properly to the correct CFM and have also successfully created duct systems in other spaces. If someone could offer insight that would be greatly appreciated. I am trying to make the duct connections manually but get tripped up with the connectors. I acheived the best results when I edited the previous generated layout. I have a 13' ceiling and 15' slab.
Thanks in advance.
