Simple generic annotation family not snapping correctly
4 REPLIES 4
abulla
2331 Views, 4 Replies
I'm making a super simple generic annotation family consisting of linework and labels. As you can see from the picture, I want lines drawn to the red highlighted endpoints to snap there. However, the point it's snapping to is apparently the extents of the larger box above. I've tried changing the lines of the box to "not a reference" and the lines I want to snap to "strong reference" and it still doesn't behave the way I want it to. How can I change the snap points of my family?
4 REPLIES 4
maciejwypych
in reply to: abulla
The snap point is an intersection of the bounding box of any annotation lines and the ref plane. So changing it's properties won't really work.
Just tick - Show border in your label's properties and remove the lines surrounding the label.
Alaaeldin_Alsahli
in reply to: abulla
Revit is limited when comes to Generic Annotation. You have two refrence planes that is taking over the snapping.
The best alterntive solution I found, is to insert a cad line in this family to help the snapping
Here is a video of how to do it
https://screencast.autodesk.com/main/details/f472c65d-2215-476c-908c-463ca5d97151
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
abulla
in reply to: Alaaeldin_Alsahli
Excellent workaround, thanks for that!
Alaaeldin_Alsahli
in reply to: abulla
Smiley Happy No problem
Alaaeldin Alsahli
