I'm making a super simple generic annotation family consisting of linework and labels. As you can see from the picture, I want lines drawn to the red highlighted endpoints to snap there. However, the point it's snapping to is apparently the extents of the larger box above. I've tried changing the lines of the box to "not a reference" and the lines I want to snap to "strong reference" and it still doesn't behave the way I want it to. How can I change the snap points of my family?
Solved by Alaaeldin_Alsahli. Go to Solution.
Revit is limited when comes to Generic Annotation. You have two refrence planes that is taking over the snapping.
The best alterntive solution I found, is to insert a cad line in this family to help the snapping
Here is a video of how to do it
https://screencast.autodesk.com/main/details/f472c65d-2215-476c-908c-463ca5d97151
No problem
