Sign into autodesk 360 keeps crashing - Revit 2013
2 REPLIES 2
868 Views, 2 Replies
Everytime I try to sign into Autodesk 360 within revit using the top right drop down menu box it keeps crashing. A small window opens saying connecting but the box remians for a few seconds and then shuts down revit.
Is there a way to fix this problem ? I have been reading around to see if its a known issue and havent been able to find any solutions.
I can Open Revit MEP log in through there and then open revit.
Edited: For some strange reason everytime I now open Revit it crashes on start up
Any help will be greatly apprieciated
Thanks in advance.
2 REPLIES 2
I am having the same problem.
When I am in REVIT 2013 and try to log into Autodesk 360, REVIT shuts down and I am unable to log into Autodesk 360.
I have tried logging into Autodesk 360 from my desktop with out being in REVIT.  I am able to log in but when I try to open REVIT it doesnt open and says "REVIT has stopped working......"
Has anyone figured out why this is happening? Or are there any solutions?
joefranco6047
Hi Nathalie,
I had the same problem, but with AutoCAD 2013.
With a bit of investigation, I found a couple of files that needed to be renamed for AutoCAD to work again.
They are located in your user directory under:
"C:\Users\xxxx\AppData\Local\Autodesk\Web Services" the "xxxx" representing your profile name in windows.
(I'm using Windows 7, in Windows XP your profile is found in"Documents and Settings")
In the "Web Services" directory, add the extension ".bak" to the end of all files
Ex. "Event.xml.bak"
Then go to "C:\Users\xxxx\AppData\Local\Autodesk\Web Services\AcSettingSync" and add the extension ".bak" to the end of the file in this directory.
Lastly go to "C:\Users\xxxx\AppData\Local\Autodesk\Web Services\AdSync" and add the extension ".bak" to the end of the file in this directory.
Restart Revit in your case.
Revit will recreate the necessary files.
The cause most probably is that you don't have admin rights on your system to modify Revit configurations, therefore Revit crashes once Autodesk try's to modify a read only file.
Hope this helps Smiley Wink
Regards Joe
