Wow. Had trouble with the subject title. Anyway, I have a lot of concrete walls that have been cut and shaped in many ways. When I do the show hidden lines command I am unable to show edges of the same object that hides them. Does that make sense? How should I work around or do this?
Joe
Make the object transparent? or go to wireframe view, then use linework tool?
Maybe you could post an image to explain it a bit more?
