Sheet Viewport Re-size
9 REPLIES 9
Message 1 of 10
sfoss
19507 Views, 9 Replies
Looking for way to resize a viewport (as you could in Autocadd) to show only portion of drawing. I have resized the crop region, however items such as room tags show up past the crop region.
Thoughts.
9 REPLIES 9
Message 2 of 10
in reply to: sfoss
Hi Scott, Crop region doesnot effect some annotation objects. May be in future Autodesk Consider this need. -- Cheers!!! BIM "Scott Foss" wrote in message news:525303.1091132380845.JavaMail.jive@jiveforum1.autodesk.com... > Looking for way to resize a viewport (as you could in Autocadd) to show only portion of drawing. I have resized the crop region, however items such as room tags show up past the crop region. > > Thoughts.
Message 3 of 10
in reply to: sfoss
The best way to go about this, is to leave the full-sized view intact with all the tags/annotations/etc. Then in the Project Browser, duoplicate the view with detailing, which will also copy the tags. Now, crop and resize this new view as necessary, and erase the tags outside of the crop region. Erasing these tags will not affect the other views. "Bim Consultant" wrote in message news:41097e87_1@newsprd01... > Hi Scott, > > Crop region doesnot effect some annotation objects. May be in future > Autodesk Consider this need. > > > -- > Cheers!!! > BIM > > > "Scott Foss" wrote in message > news:525303.1091132380845.JavaMail.jive@jiveforum1.autodesk.com... > > Looking for way to resize a viewport (as you could in Autocadd) to show > only portion of drawing. I have resized the crop region, however items such > as room tags show up past the crop region. > > > > Thoughts. > >
Message 4 of 10
in reply to: sfoss
Good One, SD -- Cheers!!! BIM "Scott Foss" wrote in message news:525303.1091132380845.JavaMail.jive@jiveforum1.autodesk.com... > Looking for way to resize a viewport (as you could in Autocadd) to show only portion of drawing. I have resized the crop region, however items such as room tags show up past the crop region. > > Thoughts.
Message 5 of 10
sfoss
in reply to: sfoss
Thanks - and obviously changes to the main floor plan drawing will be reflected in the "copy" view.
It has worked - a genius you are.
Thanks.
Message 6 of 10
in reply to: sfoss
That's the Revit way! A change anywhere is reflected everywhere! "Scott Foss" wrote in message news:25534869.1091279158218.JavaMail.jive@jiveforum1.autodesk.com... > Thanks - and obviously changes to the main floor plan drawing will be reflected in the "copy" view. > > It has worked - a genius you are. > > Thanks.
Message 7 of 10
in reply to: sfoss
Very nice Scott. That almost sounds like marketing... :-) Christie Landry Autodesk Revit Product Marketing Manager "Scott Davis" wrote in message news:410c7360$1_2@newsprd01... > That's the Revit way! A change anywhere is reflected everywhere! > > "Scott Foss" wrote in message > news:25534869.1091279158218.JavaMail.jive@jiveforum1.autodesk.com... > > Thanks - and obviously changes to the main floor plan drawing will be > reflected in the "copy" view. > > > > It has worked - a genius you are. > > > > Thanks. > >
Message 8 of 10
in reply to: sfoss
got any openings??? (in southern california... 🙂 ) "Christie Landry [Autodesk]" wrote in message news:4113dca9$1_1@newsprd01... > Very nice Scott. That almost sounds like marketing... :-) > > Christie Landry > Autodesk Revit Product Marketing Manager > > "Scott Davis" wrote in message > news:410c7360$1_2@newsprd01... > > That's the Revit way! A change anywhere is reflected everywhere! > > > > "Scott Foss" wrote in message > > news:25534869.1091279158218.JavaMail.jive@jiveforum1.autodesk.com... > > > Thanks - and obviously changes to the main floor plan drawing will be > > reflected in the "copy" view. > > > > > > It has worked - a genius you are. > > > > > > Thanks. > > > > > >
Message 9 of 10
hi.huzef
in reply to: sfoss
GO TO CROP PANEL UNDER MODIFY OPTIONS FOR VIEWPORT. THEN SELECT SIZE CROP. AND THEN JUST PLAY WITH THE NUMBERS UNTIL YOU GET TO THE VIEW PORT SIZE YOU WANT.
HOPE THAT HELPS!
Message 10 of 10
Corsten.Au
in reply to: sfoss
Hi ..
Look for Annotation Crop..
There are two crops for the view
1. Crop view
2. Annotation Crop
Annotation crop defines the visible area of 2D ..
Crop defines the visible area of 3D elements..
by the way, crop region can be a rectangle, or any polygon.. incase you want to edit it..
Corsten
Building Designer
Rail Community
