Sheet view/ view port size
2 REPLIES 2
sescadd
594 Views, 2 Replies
I am assembling my various views onto sheets.
My floor plan located in the sheet view has grips for what I assume is for the visible area desired in sheets.  I am not sure how or what I did to make these grips accessible.  I opened a new drawing and it does not seem to be in a default drawing.  When I open any of the other view foundation, roof, roof framing ect. I do not see the grips.
When in sheet view “floor plan” this area seems to have a box around it.  See attached drawing.
In the foundation view plan there are no grips and no box around it in the sheet view until you highlight it and I can not change sheet view.  See attached.
What I am trying do is fit the various views on to a sheet.  However they overlap each other. Question is how to change viewport size in sheet view so I can fit a number of different views onto one sheet.  How do I eliminate the box around the floor plan in sheet view?
I guess I am use to the Autoarchitects view ports.  Perhaps it does not work that way in Rivit.
2 REPLIES 2
in reply to: sescadd
It looks like you have the viewport active.  I say this due to the title block being greyed out.
The other reason I have found which causes the box around the view is if Crop Region Visible is selected.
sescadd
Found it..........
