You first need to create a shared parameter, File > Shared Parameters. Add
this newly created parameter to your title block family.
Now open up your project file and under Setting > Project Parameters you
need to add the parameters into your project and make sure to select
'Drawing Sheets' from the categories list on the right side of the
'Parameter Properties' dialogue box.
Now it will show up in your list of fields for your Drawing schedule.
"cmiddlemis" wrote in message
news:21892829.1106200262391.JavaMail.jive@jiveforum2.autodesk.com...
> Ok, I found it in drawing list. But I want to put a type parameter in to
the list, and it dosn't seem to be avaliable in the fields. Is it possible?
