Hi all,
I created a title block with many parameters, I have inserted this into my project. It works fine except the Sheet Number & Sheet Name parameter. I am able to input the values But these doesnt update automatically when I change the sheet number or sheet name.
Please help what Iam missing.
Thanks and Regards
Sultan Ahamed
Solved by enslinj. Go to Solution.
Solved by L.Maas. Go to Solution.
Hi there,
Could you perhaps send the titleblock to me to have a look at?
If you not comfortable posting it, PM me.
Could you elaborate more with you mean it doesn’t update automatically?
Regards
If you created a parameter named "Sheet Name" and "Sheet Number" and used that it might conflict with Revit. Revit has its own (hard coded) parameters sheet name and sheet number.
Louis
Please mention Revit version, especially when uploading Revit files.
I have attached my title block (REVIT-2015) and screen shots.
Regards
Sultan Ahamed
i even tried this in a new title block family and used those parameters, its still not working. i guess I am missing how to use the in-built parameters.
Please let me know then how to use the in-built parameters like sheet name and sheet number.
regards
First thanks for replying so quick and another BIG thanks for highlighting what I missed. Now I am confident that whenever I have an issues in Revit I can come here for solutions.
Regards
Sultan Ahamed
