Share coordinate problem
2 REPLIES 2
243 Views, 2 Replies
Hello,  I have a problem about the share cooradinate between the two model, first one is Drainage mdoel and other one is structural model. the basepoint of those two model both is N/S: 818950, E/W: 836900. But it  cannot match together when I use the revit link to link up  two model.  the image as below for your reference.
2 REPLIES 2
Alfredo_Medina
Your message does not mention what method of placement are you using to insert the links. You said the problem is the shared coordinates, but are you using that option as the method of insertion? These type of issues require more information.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
I mean that I was used the "Link Revit" this faction to link up two models, them are same coordinate setup in Basepoint. So that my question is why them cannot match together when I used the "Link Revit" to link up two models??? The problem is about the share ccordinate or other???
My method is: Insert> Link Revit> select model and Positiong is choose to Auto-Origin to Origin
