I have in Revit 2011 made a shaft in floors for a stair, how do I change shape of shaft in plan, I don't seem to be able to select it to edit boundary.
Use Tab to cycle between the different elements to select your shaft and look at the status bar to know what you're selecting. You could also use window crossing and then use filter from the contextual ribbon.
