As you can see from the screen cast I have created a section throught the building and what is happening is that the shadow from the car is showing under the soil level? Any help would be appreciated. http://screencast.com/t/IZqvchJZw0S
Solved by cbcarch. Go to Solution.
Check under Sun Settings and set Ground Plane to Level 1, not Basement.
