Setting walls at a fixed height relative to attached sloping floor ?
5 REPLIES 5
MKEllis
2768 Views, 5 Replies
I've been trying to model a set of ramps, and after discovering that I couldn't attach the wall base to the ramp, I switched the ramps to floors.
Having attached the walls to the sloping and level floor sections - is it possible to set a fixed height for the walls (say 1000m) above the floor ? |I can see how to set them to a level, or an offset from a level - but not an offset from the floor surface to which they are attached.
Anyone have any tips ?
5 REPLIES 5
MKEllis
in reply to: MKEllis
I should add that I know how to edit the profile of the wall and use the sketch tool - but I would rather find a way of linking the height to the ramped floors so that any changes to floor levels, landings and ramped sections permeate through.
AJA14
Hi. I would use reference planes. Add one along the ramp. Offset by 1000 mm. Select wall, and use attach top/base.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
wyvernwood
in reply to: AJA14
Thanks Ali,
I'm new to this - since the floor / ramp is made up of multiple sections (ramps and landings) - do I use a reference plane for each floor section (so I can have a variety of flat and sloped sections) ?
If so, how can I get the wall to attach and follow the reference planes if there are more than 1 ?
Answering my own question - do you use individual wall segments for each section of floor and attach each section to its own reference plane ?
Can you lock the reference plane to the surface of the floor ? (sorry for such a basic question - but is it as simple as adding a dimension and locking it ?)
Sorry for the vague questions - I don't have access to Revit in the office to check.
AJA14
in reply to: wyvernwood
Hi.
1- Create you wall (Entire length)
2- If wall at grid create a framing elevation, if not, Create a section passing through wall in longitudinal direction
3- Create reference planes
4- Split wall vertically at corresponding locations
5- Attach each wall seperately
Another options would be to do the following
1, 2, 3, - Same as above
4- edit profile and draw your new profile
5- Join wall where needed to get clean joints.
Ali Al-Hammoud
wyvernwood
in reply to: AJA14
Many thanks for your help Ali - I'll try that out later tonight.
Martin
