Revit Architecture
Revit Architecture
Member
Central_Standard
Message 1 of 6 (297 Views)
Setting Temp Dimension Size
297 Views, 5 Replies
08-26-2012 02:28 PM
Hi
Revit 2010
I'm trying to change the temp dimension size. (Is there anyone who can read the 8pt.?) I've looked at the .ini file and don't see where I can change it. I've also read where it can be changed via some 'option'. Under which tab and panel is the 'option'?
Hey, I'm new at this...
Central Standard
Many men go fishing all their lives without knowing it is not fish they are after.
Here is a snippet from my 2010 revit.ini file. If I remember correctly it defaults to 8 points if no entry is there, so you need to add in the line TempDim....
[Graphics]
InvertBackground=0
TempDimFontSizeInPoints=14
[Colors]
HiliteColor=16741179
Employee
loboarch
Message 2 of 6 (285 Views)
Re: Setting Temp Dimension Size
08-27-2012 05:18 AM in reply to: Central_Standard
I don't have 2010 installed to show exactly where it is, but it is goign to be close to what I am showing.  The "Options" dialog is opened from the Application menu.  The application menu is the big purple "R" in the upper left corner of the application window.  In the options dialog you will find a tab that says "Graphics" on this tab is the control for temp dim appearance.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Member
Central_Standard
Message 3 of 6 (264 Views)
08-27-2012 09:15 PM in reply to: loboarch
Thanks Jeff, but it apeears the 2010 version is slighly different. It has a slightly different set up which does not show a size selection for the temp dims. See the attached file.
I'll keep looking.
Greg
LisaDrago
Message 4 of 6 (248 Views)
08-28-2012 11:14 AM in reply to: Central_Standard
This is a newer feature - I don't believe it was aviable in 2010.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Active Contributor
peterjegan
Message 5 of 6 (242 Views)
08-28-2012 12:05 PM in reply to: Central_Standard
[Graphics]
InvertBackground=0
[Colors]
Member
Central_Standard
Message 6 of 6 (233 Views)
08-28-2012 12:30 PM in reply to: peterjegan
That's it!
What I didn't understand from some previous posts (not in this thread) that the line "TempDim....." had to be completly added. I was looking for that line to edit and of course it's not there.
Thank to all who replied!
