Hi
How can we set the parameters link below
https://www.youtube.com/watch?v=JopdkKIDwVE
One person you please answer my question
As you can see in the video, there are 2 adaptive points. There is also a dimension between these two adaptive points. This dimension has been converted into an instance reporting parameter. Let's assume that the name of this parameter is "X". Then, other dimensions that control the radius of the circles and other distances are driven by a formula, using the value of "X" as part of the formula. Therefore, when the distance "X" varies when the adaptive point # 2 is moved, the other distances increase or decrease, responding to their formulas.
By the nickname of the author "RevitCat", I think that video was made by Tim Waldock. Maybe you can visit his blog, RevitCat, for more information on similar topics.
hi and Thank you Alfredo_Medina.
Yes you are right,But my problem I have is with the formula.
How to write the formula for the.
Well, now that you got the concept, you should make an effort and do the rest. I can't tell you how to write the formula because I don't have access to that file, and probably there are several formulas in that file. Maybe try to contact Tim Waldock for more information.
