I am creating new wall types. I want bearing to be the Structual Usage default value. Is this possible?
Ludde
Solved by kathryn.langan. Go to Solution.
Whether it is bearing or non-bearing by default depends on how you are placing the wall. Regardless of the wall type you select, if you place the wall by
Home > Wall > Structural Wall
or
Structure > Wall
it will default to bearing.
Hope this helps!
