Serious Error Has Occured
1 REPLY 1
d12123486
471 Views, 1 Reply
If anyone can shed some light on my problem I would very much appreciate it.
I created a Revit model and I saved it as a central file. I can no longer open my central file as I get an error "serious error has oocured" and the file cannot load. I can open the local file and tick detach from central, abandon the worksets and the file will open.
I then "saved as" the local file with another name and closed it but I get the error "serious error has occured" when I try to open it again.
I have googled the error and there are lots of threads regarding the error but I couldn't find any similar situations.
Thanks in advance,
Laura
1 REPLY 1
CoreyDaun
in reply to: d12123486
If you can post the Journal File here, then one of the Autodesk Users should be able to investigate tha matter when they see this post.
You can find the Journal File here: C:\Users\[userinfo]\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2013\Journals
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
