Separating Level Text
2 REPLIES 2
NigelParsons4560
2003 Views, 2 Replies
Hello again,
I've added some levels that are pretty close together.  In elevation and section the labels overlap.  How do I bend or crank the elevation line at the end so that the labels don't overlap?
2 REPLIES 2
L.Maas
in reply to: NigelParsons4560
See attached screenshot. When you select the level you will see a zig-zag symbol (the top level line in screenshot).
If you click on this it will drop the label to a lower postion, like the lowest level in the screenshot.
After this you can select the level again and move the label  to different postions (by dragging the blue dots)
Louis
Please mention Revit version, especially when uploading Revit files.
NigelParsons4560
in reply to: L.Maas
So easy ... thanks.
