Revit Architecture
Revit Architecture
Member
???arch
Message 2 of 7 (323 Views)
Self created family willl not load into project file
323 Views, 6 Replies
11-12-2012 09:54 AM
I created a family and tried loading it into a project I am working on, but it will not show up.  Occassionally, the system says it is automatically making it visible, but I am not able to place it in the project.  I am capable of loading a family already provided by the Revit program (2013) just not a family I create myself.  I have used the tutorial as an example, ensuring it was a solid but that did not help.  I also checked/ turned on all of the properties settings but it did not help.
Any suggestions, Thanks in advance.
Member
???arch
Message 1 of 7 (325 Views)
Family will not load or be visible in project file
11-12-2012 09:47 AM in reply to: ???arch
I created a family using the tutorial as an example and made sure it was a solid.  After I saved it, I tried to load it  into my project but it is not visible.  I opened the properties box to make sure that everything was checked but it did not help.  Occasionally, the system indicates it is overriding something and it shows up, but it will not load. I can load a predetermined family that came with the program, just not a self created family. Can anyone offer a suggestion.  I am using Revit 2013.  Thanks
Member
???arch
Message 3 of 7 (307 Views)
Re: Self created family willl load into project file
11-12-2012 11:30 AM in reply to: ???arch
It should read; Self created family will NOT load into project
Valued Mentor
jonmcfarlandWS
Message 4 of 7 (293 Views)
11-12-2012 12:56 PM in reply to: ???arch
What type of family did you create?
When you look in the Browser, is it listed?
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
Member
???arch
Message 5 of 7 (285 Views)
11-12-2012 01:26 PM in reply to: jonmcfarlandWS
Jon
I created a Generic Model Family using the tutorial ensuring that it was a solid geometry object.  It says it is loaded, it is just not visible.
Yes, I can see it in the brower.  I saved the file in a folder other than the family library.
Valued Mentor
jonmcfarlandWS
Message 6 of 7 (260 Views)
11-13-2012 05:20 AM in reply to: ???arch
If it's in the Browser, expand the category until you see the family and then drag it into a view.  If it's Revit 2012 or earlier, post the file and I'll take a look at it.
Jon
Member
???arch
Message 7 of 7 (250 Views)
11-13-2012 07:25 AM in reply to: jonmcfarlandWS
Jon,
Thanks that did work.
