Also, sections have a property "hide at views coarser than" which will keep
the section from showing up in views with "coarse" scales. i.e. you may not
want all your walls sections showing up in an 1/8" plan, but you do want
your building sections to show up.
"sdbrown" wrote in message
news:10515684.1095286096176.JavaMail.jive@jiveforum1.autodesk.com...
> You can pick on the section and you will see a break mark in the section
line, click that and it splits the section line, then gives you grips to
stretch the line as big or small as you wish.
> you can also select multiple head/tail styles in the properties of the
section line and create as many types as you want. You can also right click
on any section line andsay hide annotation in view.
