Revit Architecture
Revit Architecture
Active Member
0 Kudos
Post 1 of 2
Accepted Solution
Section Line / Elevation View Depths
492 Views, 1 Replies
03-23-2012 11:57 AM
Hello -
2 part question:
1) How do I keep a section line from showing up in two different elevations:....have a section line in east elev.....it shows up in same spot in west elev.....but the view is the east elev....only want to see section line in east elev?
2) While looking at my west elevation, I can see things in the east elev, which is 100' apart.....how do I keep from seeing(and selecting!) things in the east elev while looking at the west elev?
Thanks for any help...
1. The Section Marks will automatically appear in elevation views. You can use a View Template to control the visibility
of annotations for views, such as turning on/off Sections. You could also create a "working Section Type" by duplicating the standard Section, and apply a Filter and set it via View Templates to automatically control visibility of the Section Marks.
2. In a plan view, highlight the elevation or section, and you will see its "depth box" which you can drag as far back into the view from the cut plane as desired. In an Elevation or Section View Properties, you can also select Far Clipping and specify a specific distance, or turn Far Clip on/off, etc.
Hope this helps.
*Expert Elite*
85 Kudos
Post 2 of 2
Re: Section Line / Elevation View Depths
03-23-2012 01:31 PM in reply to: limestonefab
Hope this helps.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Post to the Community
New Post
