I don't even know what to say. My jaw just hit the floor. How.... why... 2019... I just...
Ok, so I can't believe I have never come across this before, but in changing a callout to a rectangle, this issue has raised its ugly head. (We are trying to accomodate a large sheet number) So what fancy workarounds have people cleverer than me come up with to fix this leader not reaching the callout head??
I don't have it with me, as I am at another office, but I literally just opened a default OTB callout, and created a rectangle instead of a circle... Been playing with it for an hr here. It's simply appears to happen because the side of the rectangle is the furthest point from the centre than the top and bottom... so it snaps to the side just fine, but not the top and bottom as you move the callout...
Yeah sorry I wasn't being specific enough... try an actual view callout not a section callout. ill be in front of a compiter later and ill post an image.
This is what I get when I create it for callouts... Am I doing something wrong?
Hello guys, I could not solve this problem, but I found out why this happen and I will show my conclusions:
If you creat a Detail Head family with no anotation line on it, the Datail Line on the project will go until the cross reference line no metter with direction is the Head
If you chose to use the annotation line on the family, you have to make sure that the Line have the same distance to every side, like a circle.
If you chose to make a not square like frame, this will happen:
Now we see the Gap.
My conclusion is:
You have to use frames with the same distance to every side
I tryed to load a Annotation family but the result was the same.
Hope I could help yout guys at least to understand the way the family works.
Sorry for my poor english, not my native language.
