Where is the setting to tell the section line to begin? This line is cutting through our callout annotation circle, which happens to be sized larger than Revit’s default. See picture attached. Thanks for any help you can give. - Stacey
Solved by sconrad77. Go to Solution.
modify your callout annotation circle family and move it to other side.
That fixed it. The thing that tricked me, is that I had to turn on the reference planes and move the callout and the reference planes. Thanks so much for the help. -Stacey
