Searching a best book teaching Revit?
5 REPLIES 5
jz4all
2267 Views, 5 Replies
Is there anybody  (based on experience) can advice me which is the best book for teaching Revit for beginners step-by step?
The lanuage can be in English or Dutch.
Jaf
5 REPLIES 5
LisaDrago
in reply to: jz4all
I have used two books -
Ascent - Autodesk Revit Architecture 2013 Fundamentals - Imperial. I use this one through my Autodesk Training Center.
Sybex - Autodesk Revit Architecture 2013 Essentials. I use this one at a community college I teach at.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
jz4all
in reply to: LisaDrago
Thank you Lisa,
What did you mention are good. But also I found an other book also good.
It is ( Autodesk Revit Architectrure 2013) by Eric Wing. The mentioned choices are good and if I don't not find beter I'll choose one of them. Because what realy I need, a book hoe leads me step-by-step without using a help from a teachter in this time. There are such books in the Netherlands but about AutoCAD and Inventor and I used them.they are fantastic but in Rivit I didn't find.
thanks again
Jaf
in reply to: jz4all
The best Revit books for beginnerss and intermediate leveles are by CADCIM Technologies and Prof Sham Tickoo.
Revit Architecture, Structure, MEP, Coordination  2011,2012,2013, and 2014
Autodesk Reviit Architecture 2014 for Architects an Designers: smileyhappy:
Exploring Autodesk Revit Structure 2014
Exploring Autodesk Revit MEP 2014
Exploring Autodesk Navisworks 2014
Exploring Autodesk Vasari
Exploring Autodesk Ectotect Analysis
http://revitxperts.blogspot.in/
http://www.cadcim.com/civilgisbooks.aspx?ShortName=Revit%20Architecture
Best Price, best content, and easy to learn
Rating:*****
Mike D
scott
I am trying to find a good book/guide to use NWS as an accurate and simple estimating/quantity program for Revit files.  Is there an animal like that out there?
Should I look someherer else?
scott
