Revit Architecture
Revit Architecture
New Member
jasonmelling
Message 1 of 3 (858 Views)
Screen Resolution requirements - Set in stone?
858 Views, 2 Replies
06-07-2011 08:52 PM
So the resolution for 2012 Revit is 1,680 x 1,050 monitor with true color, according to the system requirements on the product page.
Is that a REQUIREMENT? Can I use a monitor with a smaller screen resolution?  If so, what will I be sacrificing?
Thank you so much.
Employee
ryan.duell
Message 2 of 3 (830 Views)
Re: Screen Resolution requirements - Set in stone?
06-10-2011 06:48 AM in reply to: jasonmelling
You can technically use a display with a lower resolution but it will collapse some tools and some larger menus may not display as desired.  For example, the tools may appear similar to the image below in a collapsed state or with smaller icons:
Image Example
The recommendation was the resolution the application was built around as a best starting point.
Thank you,
Ryan Duell
Autodesk, Inc.
Revit Clinic
@revitclinic
New Member
jasonmelling
Message 3 of 3 (812 Views)
06-11-2011 07:03 PM in reply to: jasonmelling
Nice! Thank you.  I went ahead and purchased a 21.5" monitor with a 1920 X 1080 resolution.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
