Scheduling Generic Model Category
14 REPLIES 14
Message 1 of 15
7433 Views, 14 Replies
Is there a good reason why you cannot *only* schedule the Generic Model
Category in RVT 2010?
(not sure if this has been fixed in 2011?)
The way I see it,
the only way to Schedule Generic Model objects is to create a Multi-Category
Schedule,
and then hopefully you have a nifty way to filter that Schedule down to only
the items that you need.
Is this purposeful? or an oversight?
14 REPLIES 14
Message 2 of 15
Not sure, but in general I try to avoid creating anything that is left
categorized as a "Generic Model". Even if I have to use a Generic Model
template to get the family to behave the way I want, I always categorize it
as something explicit right off the bat. Leaving it as a Generic Model to me
is comparable to drawing on the layer zero in AutoCAD, except worse, because
the only way to "fix" it is to edit the family again.
What kind of object is it that you've created as a Generic Model that you
want to schedule? Perhaps you can categorize it as something else - if
necessary putting it on a subcategory.
"caLayton" wrote in message
news:6382298@discussion.autodesk.com...
> The way I see it,
> Multi-Category
> Schedule,
> only
Message 3 of 15
"Matt Dillon" wrote in message
news:6382332@discussion.autodesk.com...
> want to schedule?
actually, Matt,
the item is question wouldn't normally be scheduled (except maybe for
costing?);
I just happened to decide to schedule it to error check a Family I'm making
that
includes a single instance of a nested Family or an Array of that Family
(thanks to the no single instance array rule in RVT)
I was getting an error message about identical instances on top of
eachother,
and wanted to verify that the not Visible single instance (coincident with
Visible Array instance #1...)
wouldn't really schedule, even though RVT warned that it would.
(It doesn't)
Message 4 of 15
> it
> me
> because
and not to pick a fight,
but these kind of flip, non-answers regarding perceived "holes" in in the
software,
are what really turn-off new or potential users seriously looking at RVT,
FYI.
Just don’t use Generic Models?
Is that really how to solve the issue?
If "Generic Models" Category is useless, why include it in the software at
all?
But please don’t take offense, though, Matt?
I really value your help.
I don’t mean to single-out your post, in particular.
It's just that occasionally, these oddities arise, and for some reason
moreso with RVT Users than any other software I use or have used;
the issues are willfully avoided rather than discussed/tackled.
I've never understood why?
(maybe I didn’t get the proper dosage of Kool-Aid with my installation dics?
Message 5 of 15
You have to request that separately through Subscription Center,
otherwise they don't ship it to you. 😉
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
Message 6 of 15
It wasn't meant to be a flip non-answer.
In my opinion, the generic model templates are there to provide a workaround
when the standard template won't work.
For example, Let's say I want to model a door handle to be used as a nested
family in a door family. I certainly don't want to use the default Door.rft
template, because then it will want to be hosted by a wall.
So instead, I use the Generic Model - Face Based.rft template so that it can
be hosted by the door panel itself, but I don't want it categorized as a
Generic Model, so I categorize it as a Door, and then define a "Hardware"
subcategory to put it on.
news:6382382@discussion.autodesk.com...
>> it
>> me
>> because
> software,
> FYI.
> all?
> dics?
Message 7 of 15
BTW - if I wanted to give you a flip-non answer, it would have been more
along the lines of
"That's the way it is, STFU and deal with it."
But I didn't do that, did I? 🙂
>> it
>> me
>> because
> software,
> FYI.
> all?
> dics?
Message 8 of 15
parveensharma2130
Dear All,
You can schedule Generic Model Category.
See attached image for more details.
Hope this help.
Parveen Sharma
Eigen Technical Services (P) Ltd.
Message 9 of 15
"parveensharma2130" wrote in message news:6382587@discussion.autodesk.com...
Material Takeoff, yes.
Schedule/Quantities, no.
Message 10 of 15
news:6382410@discussion.autodesk.com...
no.
thank you for not saying that. 🙂
Message 11 of 15
Matt,
I think that you've rolled the *templates* into the intent of the
discussion,
which is really only about the "Generic Model" *Category*.
I am going to consider playing around with your suggestion to create
sub-categories under the "good" (anything *but* Generic Model...)RVT
Categories, though. But if I create a sub-category, does it buy me anything,
other than more granular graphical control? I mean, say if I create a
sub-category to Specialty Equipment named "Lockers", for example. Can I then
Schedule *only* the Sub-Category "Lockers"? (I haven't noticed anything in
the current RVT interface that would suggest this...) If so, that would be a
perceived benefit.
Message 12 of 15
I don't believe you can filter a schedule based on sub-category. You'd have
to use something else - perhaps even a custom parameter that you attach to
all Specialty Equipment objects that would serve as something similar to
classifications in ACA in that regard.
news:6382737@discussion.autodesk.com...
> Matt,
> discussion,
> anything,
> then
> a
> perceived benefit.
Message 13 of 15
news:6382740@discussion.autodesk.com...
Thanks for the clarification, M.
That's what I had suspected.
>You'd have
Using Assembly Code has worked well for me so far, to date.
As long as the data is entered correctly!
Message 14 of 15
parveensharma2130
Please specify the field/columns you want in your generic model schedule.
My opinion says, You can extract all information about generic models with above mentions (Quantity take off) method.
Message 15 of 15
Thank You!
So glad I came across your post today, showing how to use the material takeoff category to schedule a generic model.
I'm trying this method to schedule kalwall panels for contract documents, and it looks like it should work.
