Revit Architecture
Valued Contributor
DavidRaines
Message 1 of 7 (282 Views)
Schedules
282 Views, 6 Replies
12-11-2012 05:57 PM
How does one remove unused doors and windows from schedules.
thanks
David
Active Contributor
sagar.londonites
Message 2 of 7 (266 Views)
Re: Schedules
12-12-2012 12:16 AM in reply to: DavidRaines
Unused items are by default excluded from schedules.
If anything appears in schedule, you have used it in model.
- Sagar
mike
Message 3 of 7 (257 Views)
Re: Schedules
12-12-2012 04:24 AM in reply to: DavidRaines
As Sagar stated, it an Item is in ANY schedule, it has been placed into the model somewhere.  To get rid of an item, you must delete from the model/drawing window.  If you cannot find it by 'site' alone, you can go to schedule, click on the offending item, and at the top you'll see a button go hot that says "SHOW"  .Click on the Show button and it will take you to the object in the model.
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
Building Design Suite Ultimate 2013, 2014, 2015
Charlotte, NC ; Fort Mill, SC
Valued Contributor
DavidRaines
Message 4 of 7 (207 Views)
Re: Schedules
12-20-2012 10:52 AM in reply to: sagar.londonites
Not True, I have doors 10 thru 35 used and door 36-78 as repeatitive doors with a new number in the schedule. I have  tried purging without avail.
thanks
David
CADastrophe
Message 5 of 7 (202 Views)
Re: Schedules
12-20-2012 11:23 AM in reply to: DavidRaines
The Doors and Windows may exist on another Phase or perhaps even on a Design Option. Try these two methods of locating them:
1. From the Schedule, click on a line of data for one of the Doors that shouldn't be there. On the ribbon, click "Highlight in Model" to select all of the elements that fit the criteria of that line of the Schedule.
2. From the Project Browser » Families, find one of the Families that shouldn't be appearing on your Schedule. Right click on the Type and choose either:
   · "Select All Instance in Project" - the amount of elements present will be display next to the Filter, in the bottom right corner. If there are no elements of that Type, this option should be grayed-out.
   · "Delete" - This will forcefully remove it the Project, but it will first report how many instances will be deleted. The process can be canceled.
Valued Contributor
DavidRaines
Message 6 of 7 (197 Views)
Re: Schedules
12-20-2012 12:19 PM in reply to: mike
I did as instructed (I think) and I deleted all doosr for in that instance. I cannot seem to delete unwanted doors or separating the doors so one can delete unwanted.
thankd
David
rosskirby
Message 7 of 7 (151 Views)
Re: Schedules
12-24-2012 05:52 PM in reply to: DavidRaines
I've found that in a lot of cases, all you need to do is make sure that the phase filter for your schedule is set correctly.  Go to the schedule, and in the properties palette, make sure the phase is set to new construction, and the phase filter is set to "show new".  This will filter the schedule to shoes only the new doors, and none of the existing or demolished ones, which I'm assuming is what you're after, although your post is a little unclear on that point.
However , if you want too selectively show a certain range or mix of doors, you'll have to do it via thpeople filter tab in the schedule properties.
Ross Kirby
BIM Manager
Arcturis
