Schedule Text
4 REPLIES 4
DavidRaines
497 Views, 4 Replies
Schedule Text
It is normal or has been in Architectural history to have all text in upper case. However schedules come in lower case. Of course this can be edited but that is time consuming. So, how can I default my schedules to be always in upper case?
David
4 REPLIES 4
scott_d_davis
in reply to: DavidRaines
The headings can appear in upper case if you set them up that way in your template.  The information in the schedule will be upper case if thats the way its entered into the family that is supplying the schedule with the info.  Again, this is something that could be set up in advance in your template so each new project the schedules are in upper case.  It will also take some understanding from your users that they must also enter data in upper case for it to appear in schedules that way.  There is no built-in automatic way of turning all text to upper case, although there is a third party plug-in that does this.
Scott D Davis
Sr AEC Technical Specialist
DavidRaines
Thank you for responding. I will get right at it.
David
DavidRaines
DavidRaines
in reply to: scott_d_davis
What third party application?
