Schedule Help Please Total Count for Graphic Parameter
3 REPLIES 3
Sandra.Massa
1155 Views, 3 Replies
Thanks in advance for any help as I am stuck at the moment.
The attached schedule is all good except that I want to get a total for  the columns Duplex, Duplex GFI, Fourplex,
and Simplex. The schedule only shows the (1) column at the moment Duplex Total created as an additional paramter with calculated totals in the project.  I am trying to link that to the Duplex column etc...,
Please note that those columns Duplex, Duplex GFI, Fourplex, and Simplex are graphical yes/no paramters for my all in one outlet family created using the annotation symbols separatey loaded in a 3d wall hosted electrical family
then turned off and on accordingly.
 It's all working nicely expect  that the different heights are counting separately, when I want a total
of just Duplex's, Simplex's and so forth.
bluicat
3 REPLIES 3
cosstroe
in reply to: Sandra.Massa
 go i Properties > FORMATING > Schedule Properties >Formatting and click then in left side :Field :Duplex> in the right side :  Field Formatting > Calculate Total ...CHECK IT
Sandra.Massa
in reply to: cosstroe
When I go to formatting and select Duplex the field for calculating totals is greyed out.  The only parameter that is not greyed out is the one that I added which is Duplex Total.  I think that I have to do some type of calculated value to link the Duplex to the added parameter Duplex Total?
bluicat
Sandra.Massa
I figured it out.  I needed to create a shared parameter with an integer  - then I was able to connect it to outlet families and report the count.
Thanks for trying to help me anyway
bluicat
