Saving
2 REPLIES 2
chriscalder07
2449 Views, 2 Replies
Saving
Hi there, Hopefully someone can help me with a problem
I have Revit 2011 and am working on a project that I have left open. I last worked on it yesterday morning and had saved my work.
I have come back to it today and wanted to close the project and work on another one.
It wont let me save. says file not saved.
If I go to my revit files, it says that the last save on revit file was a month ago!!
Do not want to close the programe.
If I minimise the project and open another project it will allow me to save that project as per normal.
I can then open the project that I am having the problems with by using tile view, and it says
"The document has changed since it was last saved. To revert to the saved version, close the document first and then re-open it."
I close that info window and this one comes up.
"This file is already open for editing by another user.You will be unable to save any changes before that user closes the file"
I have not shared the file with any other user.
Does any one know what I can do. as I am scared to close and dont want to do more work if I am unable to save it.
2 REPLIES 2
use Save As and save it under another name
Constantin Stroescu
Love you!!
