saving the central file to 2014 help
2 REPLIES 2
jjnapicone
191 Views, 2 Replies
i just installed 2014 and i get this message saying i have to log into a different account that has no elements cheched out....help?
2 REPLIES 2
Thank you for your post. In this case, have you tried to cut a new central file? This may help overcome this instance. To do this you would save-as, select options, from this menu you can select the check box for create a new central and then compare overall results. If this does not work, could you post a sample copy of the file in question for testing? Please let us know if this helped. Thank you.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
jjnapicone
in reply to: jjnapicone
Thanks. That's exactly what we did and it worked.
