Show only
Search instead for
Thank you for your post. In this case, have you tried to cut a new central file? This may help overcome this instance. To do this you would save-as, select options, from this menu you can select the check box for create a new central and then compare overall results. If this does not work, could you post a sample copy of the file in question for testing? Please let us know if this helped. Thank you.
Michael Bussiere II Support Specialist Product Support Autodesk, Inc.
