Revit Architecture
Revit Architecture
Valued Contributor
5 Kudos
Post 1 of 5
Saving .rvt files to Lion Server
506 Views, 4 Replies
10-23-2012 08:32 AM
We are running Revit 2012 Suites on iMac w/Parallels w/Windows XP SP3.  Office file server is a Lion Server running 10.7.5.  While working in Revit we can; save PDF's to server, export DWG/DXF to server, and for a few moments after opening a file we can save a .rvt file to the server. But after more than ~2min, Revit freezes at any save attempt and we have to force quit through the task manager.
Last few lines of journal entry for event reads as follows.
[ Jrn.Directive "DocSymbol"  _
         , "[Res.TemplateLionTest.rvt]"
 '  0.000008    2:<<<BackupFileManager::smileytongue:reUnlockPreCommit
 '  0.003275     3:<<<relinquishAllLocks
 '  0.003386    2:<<m_oSaveToTempFile->preCommit
 ' 2:< Error encountered renaming main file to backup. Error message: Access to P:\Projects\XXXXX Project\CAD\Revit\Res.TemplateLionTest.rvt was denied.   ]
then repeats the '2:< Error... line for a few pages..
this error has persisted throught Revit 2011 and 2012 versions.
Anyone else encounter this? Possibly with solution?
Valued Contributor
5 Kudos
Post 2 of 5
Re: Saving .rvt files to Lion Server
10-26-2012 10:26 AM in reply to: GPR_MN
So, is the lack of response from anyone in Autodesk due to Revit not being supported in a Mac environment? Apparently I'm not the only one with issues in saving .rvt files to a Lion Server.
Product Support
30 Kudos
Post 3 of 5
10-29-2012 09:44 AM in reply to: GPR_MN
Correct, this environment is a not supported.
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Valued Contributor
5 Kudos
Post 4 of 5
10-29-2012 10:55 AM in reply to: GPR_MN
ah, a non-solution solution. thats great. i should just pile on the kudos eh?
maybe you could have left it 'unsolved' on the chance that one of us subscribers may have figured something out.
Valued Contributor
5 Kudos
Post 5 of 5
04-01-2014 06:52 AM in reply to: GPR_MN
Well,
If you buy a car that runs on diesel, don't expect help if you try and run it on gas.
