Solved by loboarch. Go to Solution.
Solved by paul.ashley. Go to Solution.
Solved by ljhudson. Go to Solution.
Solved by Elmo. Go to Solution.
Solved by DavidRaines. Go to Solution.
Solved by derrickmoore. Go to Solution.
That answer isn't satisfactory. All new software contains new 'features' that the previous version didn't have. Revit's content isn't new per version.
Does Archicad or other BIM type softwares allow save down to previous versions? We all know what the real reason is.
They should at least let us use an "export to previous version" tool and let us choose to update OR NOT an existing file where we will do only some basic changes !
I'm the only one to work on Revit 2011 and Civil 3D 2011 in my company ! everybody else is on Acad with different Releases licenses (from LT2000 to 2011)
So when I make something in Civil that I've to give to someone else, I HAVE to export it from civil to ACAD otherwise they will only see a dumby empty dwg
When I'm in Revit 2011 I can't event export my 2011 rvt to a dumber 2010 rvt with some massing elements or open a subcontractor's RVT2010 file, move some walls, without converting it to 2011and making it unopenable for them... that's realy silly IMHO !
At least the latest version should be able to open, edit, and save back a project created in a previous version. So now if consultant A has Revit 2008, consultant B has Revit 2009, and consultant C has Revit 2010, they can't work together at all? OK, they could all upgrade to 2011, but then they would lose the ability to work with anyone who uses a previous version. What's the solution, besides having a license for every release?
Subscription allows you to keep and run older versions of the software. Up to 3 years older.
What about template files can you share them across different versions, or do you have to create dupicates of each on for each version?
Also, If a project was created on a different version, what happens?
Does the file get corrupted or does it not even open up?
Templates and project will be promoted to the newer version if you open them in a newer version of Revit. If you save after that they will be in the version they promoted to. They can't go back.
As far I understand the main reason why you can't save backwards is more to do with the fact that the program is a database program. Historically database programs have issues with backwards compatibality. If you look at ACT from Sage it also doesn't allow for backwards compatibility. I don't know the full reason but I believe that since the coding is so heavy it usually crashes because the code from the newer version can't match with the code from the older version.
Microsoft Access is a database program and it saves 2 versions back
Microsoft access is a very basic form of database coding. Even the guys that do heaving coding inside of it, don't really want to go backwards because it can get screwed.
Btw I find that you trying to compare Microsoft acces to Revit's coding very laughable.
So how would some one deal with not opening a revit file in a different version?
example of why I ask. is you structure your project folders with Drawings section and a documentation (project admin stuff)
verses structuring you jobs by what program you are using.
Not sure If I explained it correctly, but I am sure someone has came arcoss this
Here's a major problem with this entire backwards compatibiltiy issue. Revit also can have problems opening much older versions in new versions.
I found an example Revit file on an old Autodesk Revit "gallery" page. It's a completly documented library project. I downloaded it but after several error messages, it won't open.
My concern is how this affects archiving of Revit projects. I have ten-year-old AutoCAD R13 files that I can open. Some must be recovered but they nevertheless do open.
Since Revit upgrades do not support backwards compatibility it seems they may also not always support forwards compatibility. If an inability to open an old Revit file is a common thing, this has huge implications for Revit's use for facilities management and historical record-keeping. Has Autodesk considered how this issue can be resolved? Are we supposed to upgrade all drawings of active and inactive files with every new version of Reivt?
See my reply to your other post in relation to this issue.
What I don't like about not be backward compatable, is that you have to keep multiple versions of Revit on your machine. As of now, I have 2009, 2010, 2011, 2012 all on my machine, I also only have AutoCAD 2012. those 4 versions of revit take up a lot of space on my drive.
Jeff,
Our school is using Revit 2010 and 2011. We are on subscription. How can I save back from 2011 to 2010.
Subscription allows a 3 year save back right? Thanks. File-Save As doesn't give me options to save to a previous version.
