Just installed 2011 Revit Architecture and when trying to save during a work session, multiple copies are being created instead of overwriting the main file? Where are setting options to adjust this?
Solved by E.felps. Go to Solution.
Everytime you save it will make a back-up file typically with numbers in the name XXX.0001.rvt.
It is saving back to the origional as well as saving a back-up.
I believe the default is like 4 back-ups.... so you will have xxx.0001.rvt, xxx.0002.rvt, xxx.0003.rvt, xxx.0004.rvt... once you get to the 5th back-up it will drop off xxx.0001.rvt and you will see the xxx.0005.rvt
LD
OK, but it was up to 15.rvt and counting. ACAD is a hard methodology to re-think when you need to maintain production drafting.
It will keep counting - I have been up in the 100's before. If you want you can delete the back-up's. I would always leave 1 just in case - you know how it is...
BTW - if you are happy with the response don't forget to accept as solution.
LD
