Does anyone know how to save a file as a PDF in Revit Architecture 2014? I have tried going to print and then just save as a PDF, but there is not a PDF option.
Thanks!
instal PDF Creator or Bullzip PDF Printer or other pdf printer....if you already have it installed for a previeous version you must be able to use it in R2014....
Your Name
Once I download PDF creator, will it give me the option to save as a pdf in Revit 2014?
Instal PDF Creator....you'll find it as a virtual printer in Print under Application Menu (big R).
In my case I made an upgrade from R2013....so all the printers installed for R 2013 are now available in R2014..
Your Name
