Hi
How do I save the printing settings for different size sheets
Currently I have, each time I want to print, to select the printer, select the reqired size and set it up and print .. is there not a way to save this info to that specific sheet and size - so next time I want to print it I can just press print?
Your help would be greatly appreciated.
Edward
While you can save presets as you mentioned for the printer and pull-down saved names for the paper size \ additional settings, you cannot link these to specific Revit sheet views.
If you change this under the Print Setup of the project, all the sheets in the project would use the default Print Setup name.
I would recommend requesting this feature with the product teams below:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you,
